knnthkong
Responses not editable
Hi experts,
I am having a problem with hyperstudy where the responses were wrong and not editable. I tried to do like tutorial (HS-2200). The errors are:
414 Error : Design matrix should have at least one active row ( 0 )
              Unable to generate design for ( Fit 1 (fit_1) )
 415 Error  : Error generating design - ( Fit 1 (fit_1) ) - ( Moving Least Squares )
I attached my work file. When I tried to edit the run matrix, it was not working. Please give me some idea. Thanks.
nom_1_runsummary.data
nom_1.sqlite
fit_1_inputmatrix.dat
fit_1.sqlite
doe_5_runsummary.data
doe_5.sqlite
doe_2.sqlite
response.csv
morrow.hstx
Study_1.xml
Study_5.xml
study_lock.xml
Dear Rahul,
Thanks for the prompt feedback but the problem is every time after put in the response, hyperstudy automatically wipe it off. What I do is under DOE "approach", then "Specification", then "Modify Run Matrix" and put in the response value. After I click apply and then ok, the responses become "empty" when I checked it.
I have replicated HS 2200 in latest version HW 2017.2.Please find below ftin link to download mp4 file of tutorial.
https://ftin.india.altair.com:8443/message/SEaMOMscYhlNk8d1Bpma9L
I see the csv file which you have copied does not contain Design variable and output response in column like tutorial.Let me know if attached video helps.
