Hi everyone, i would like to know if there is any tcl that extracts the midline of all displayed thickened pipes comps. If not, is there way we can create a tcl to extract midline for all the displayed hollow thickened pipes..
Thank you in advance
hi nyuyen , i mean midline of a solid cylinder with some diameter (lets say 100mm). Pls Imagine there are some, 50 cylinders of such kind or say wires ( unattached to each other) and i want to extract midline for all of them at once using a tcl..... unfortunately i dont have the model so couldnt attach.. i am however attaching an image for ur understanding
thanks in advance
Hello everyone, I'm retriving this topic again in order to see if someone could help me.
I have a 3D model (tubular structure) I want to mesh with 1D CBAR elements.
Anyone please know a quick way to get the midline of the 3D model tubes?
Thanks in advance.
Hi tinh,
Thank you for your attention to this matter.
I'm not really seeing your point.
I have a strucutre like this and i need to extract all midlines (in blue) in between.
Could you please be more clear?
Thanks
Ok I got it, thank you so much Q.Nguyen-Dai and tinh.
But know I have another question, because I have a big structure I do not want to do all the process by hand ( that would be very time consuming)
Is there a TCL scripting code to that automatically? I mean just selection all teh tubular structure at once and give me all the midlines?
Thank you for your kind support.
A such script is not yet found.
If you find it or write it, pls share us.
I think it is rarely used so nobody write.
Attached the sample picture of geometry.  I want to write a code to extract the midline of the tube and calculate thickness. greatly appreciate of anyone can help me
Ya. I know CAD software can do it on fly. but I need to extract in Hypermesh.  Its the first step in my analysis and I always gets CAD without midlines.
I tried writing TCL code for this by sequentially selecting outer parallel lines and finding midlines and joining all of them. But I need more robust code
That's problem if the 2 lines are not slice the sequence in 2 equal parts.
To specify mid line, i suggest you to extract parametric uv lines of each outer surface. In simple case you will get u or v as arcs, find arc centers and connect them you will get mid lines
