Mayur Deshmukh
Element quality check error
You can create parameter card by using; Tools > Create Cards > PARAM  and after that you must activate 'CHECKEL' option and choose 'NO' under the PARAM card.
But you must be careful when you eliminate the quality check, it can affect your results in some cases.
Recommended range violations can be eliminated but you shouldn't be outside of validity limit. I think some of the elements quality is really too bad and solver can not exceed this issue. You need to control the mesh.
