How can I see, in the simulation of the propagation of all antennas (RUN PRO), the total power of all antennas? I am only able to see the power/field strength/etc. of only 1 antenna per time and not the power/field strength/etc. of all antennas together.
There are two ways to compute the total power of all antennas.
Either by defining a network planning project in ProMan using an air interface definition (wst) file. Then by using RunNet the propagation results for the individual antennas will be superposed and the total coverage and interference situation is computed.
Alternatively you can load the first result (*.fpp file) in ProMan and combine the results for the further Tx antennas via Edit => Combine Data => Max Value.or via Edit => Add Data => delog (incoherent).
I managed to combine all the antenna results. But I was thinking about the difference between Max Value, Mean Value and Min Value. You know something about it? How the results combine each other in these three different cases?
