KevinE
Fiber Orientation [Composite PostProc]
Hi all,
I want to Display a Contourplot of the Fiber Orientation using Hyperview. I found a documentation .PDF (HF-Training_Composite_Forming) on the Internet with a reference to a file called "Expression_builder_fiber_orientation.txt", but I don't know where to find this .txt file. The Expression in this .txt file seems to be pretty complicated.
Does anyone know where to find this file or how to do a Contourplot of the Fiber Orientation in another way?
Kevin
Hi Rahul,
thank you for the answer. But that's not what I meant. I attached two Pictures which should make my question a little bit clearer.
I want to Display the Fiber Orientation in every Element and am looking for the correct Expression to Input in the Derived Results Panel.
Kevin
try with below expression.
VectorFromScalar(cos(S4),sin(S4),0.000000000000,"elem")
