Sign in to follow this
Oli
SPCD displacements
I used "fields" to transfer displacments and rotations from a model with a coarse mesh to a model with a fine mesh.
There are different Interpolation Options available.
How can I read (show) all displacements/rotation in the createted SPCD's (maybe in a table) before solving?
Yes, like in the Picture below. I want to see the displacements/rotations for all SPCD's in one load collector. I just know how to display a single one. Would be great to have get table with all dis/rot from one load collector.
Hi Oli,
Unfortunately I couldn't find a script to write out SPCD data to text file or some other format.
You can either write your own script or get from .fem file
This template may help (run by command *usercheck spcd.tpl spcdout.csv 0)
file spcd.tpl:
*loads(3,2,"SPCD")
   *format()
       *string("SPCD,")
       *field(integer,collector.id,0) *string(",")
       *field(integer,location.id,0)
       *if([comp1!=-999999.0])
            *string(",1,")
*field(real,comp1,8) *end()
        *endif()
        *if([comp2!=-999999.0])
             *string(",2,")
*field(real,comp2,8) *end()
        *endif()
        *if([comp3!=-999999.0])
             *string(",3,")
*field(real,comp3,8) *end()
        *endif()
        *if([comp4!=-999999.0])
             *string(",4,")
*field(real,comp4,8) *end()
        *endif()
        *if([comp5!=-999999.0])
            *string(",5,")
*field(real,comp5,8) *end()
        *endif()
        *if([comp6!=-999999.0])
             *string(",6,")
*field(real,comp6,8) *end()
        *endif()
*output()
