jaynice
Problems with DXF import
Hello all,
i've got a problem with flux and the import of some dxf files (created with solidworks). Sometimes the ok button for the import confirmation seems "inactive" and couldn't be pressed after i selected the desired file.
The file names don't contain any space or backslash..
Thanks for your help!
Can you counter check there is no "strange" character in the name ? I believe the - sign is not allowed for instance. It is better if the name is short (and also the length of the path since the root part C,D,E,..., as there is a maximum length).
I hope it will help.
hi lombard,
thanks for your fast aswer!
Obviously it has to do with data content by itself, because neither a short name without any strange characters nor a short path solved the problem.
In addition, a few other files in the same folder can be imported trouble-free.
Do you have another guess?
