Praneeth.smk
Temperature mapping.
Hello.
I'm currently working on a thermo-structural analysis of a telescope. The structural and thermal analysis has been carried out separately with different mesh (structural analysis mesh-330000 elements, thermal-5000 elements). The thermal analysis with a coarse mesh comprising of 5000 elements, is done in NX and the temperature data at a particular time step is extracted in excel format. Now, to perform thermo-structural analysis in Hypermesh, i have to map this temperature data onto the fine mesh (330000 elements one). But i'm struck here. I have no idea how to import the excel data. Another problem is that the mesh is also different. I'm going with the optistruct solver as i have to introduce mechanical loads onto the telescope apart from thermal loads.
How to proceed with this problem? any suggestions are welcome. Thanks.
On 1/16/2018 at 5:18 PM, Q.Nguyen-Dai said:
Try method "linear interpolation"
"nodes" => fine mesh
"file" => temperature field from txt file in form :
X-coordinate Y-coordinate Z-coordinate Temperature
Can you please share any the run-able fem file for my reference, ?
Hi Q.Nguyen-Dai,
i have followed your method but not succeed. (i tried with several different models)
the temperature load in Hypermesh (after linear interpolation) is all "0-zero" value.
Can you help check my attached files in below?
Thanks in advance!
hanlde.hm castRun_S.h3d Coordinate-contour.csv
