emanu92
Fluid thermodynamic properties
Thank you for your answer, ydigit.
Assuming that I can import a three-column csv file (pressure, temperature, density), How does aAcuConsole know that the first column represents temperature, etc...?
If your property needs to be a function of two different variables, you'll need to use a user function.  AcuSolve does have pre-defined isentropic and ideal gas density available, which may be what you need.  The Command Reference Manual will have an example user function in the material model (or density model) section.
