Sign in to follow this
Yogi Adi Wijaya
Transformation from Global to Local Coordinate
Good afernoon ladies and gentlemen.
I am Yogi, a students from Indonesia. I have a problem to using local coordinate, using RADIOSS software. The problem begin, when I am finished input the new 'local coordinate' (system), and inputed the imposed (VELOCITY) using Y-Direction.  How, I change the direction of IMPVEL from Y - direction at global coordinate, became to Y - direction at local coordinate. Please hel me, to sloved this problem. Thank you.
Yogi Adi Wijaya
While defining the imposed velocity (/IMPVEL) we have the option to select the local skew created. Please select the skew here so that the load will follow the defined skew.
Hi Johnson,
I have included the influence of skew, but the results is sill not good. Then, I read a reference and found the difference between 'SKEW' and 'FRAME'. I think in this case, I must created the 'local Frame' . So, how to apllied the local Frame and then assigned to Imposed Velocity ?
Yogi
Create the local system and card edit the system to change it to 'frame'.
To update the same in /IMPVEL, card edit the same load collector and update this frame as shown in the image below.
Hi Johnson,
I have tried to change a IMPVEL direction from global to local coordinate, but still can't be worked. Maybe I give you a RADIOSS file, to help me how to change the velocity direction from 'X global coordinates' to 'X local coordinates'.
Please, help me to solve this problem. I am waiting four your answer, thank you.
Yogi
Need_help_0000.rad
Need help_0001.rad
Hi Yogi,
I just created a local system and assigned the same to /IMPVEL and it works fine. Create your local system and assign.
In HyperCrash you can always review the loads applied.
model1_0000.rad
