I'm doing an analysis of  sloshing with a fuel tank.
The total event time is 0.7 seconds. On time around 0.4 seconds, the run did stop and this follow message appears to me:
MESSAGE ID :          174
 ** ERROR : NULL DIAMETER FOR SPH PARTICLE ID=21643
     ERROR TERMINATION
I'm using a controller of time-step do run this model.
Would somebody help me?
Best regards,
4_0001.rad
4_0000.out
4_0000.rad
4_0001.out
But, seeing the 0000.rad and 0001.rad, I noticed that you changed the contac (You used SURF_EXT set, to select the fuel tank and GRNOD set to select the fuel) before i was using the seletion by components. Can you learn me the diference? On 0001.rad i noticed that you removed tha controler time-step by INTER e leaved the controler by NODA. Do you think the controler by INTER caused this error?
