Umarrr
Simulating channel characteristics with directional beams from antenna arrays
Is it possible in WinProp to simulate channel characteristics with directionals beams from antenna arrays at millimetre wave carriers? Also  is it possible to simulate beam steering?
in WinProp you can simulate the channel characteristics including an arbitrary antenna pattern, also at mm waves.
However the beam steering is not simulated, i.e. you would need to create the "typical" antenna patterns resulting from the beam steering outside WinProp and then use them in WinProp for simulating the channel characteristics.
Umarrr likes this
