Imre
Composite coupon test in Optistruct
Hey Guys!
I have experimental data for composite tension compression and bending (3-point and 4-point) due to my university and I want to make a material card that can describe all of the mentioned test (and behavior) with proper accuracy.
I would like to make tension, compression and bending (3-point and 4-point) test in Optistruct but I haven't make coupon test before. In the real tests the loads (movement of the clamping jaws) move at constant velocity. I have no experiment how to model such kind of load in Optistruct.
I think there should be some non-linearity in the test because of the large displacement. How should I properly model such kind of problem? Do you have any experiment in modeling with velocity load in Optistruct?
A further problem will be the bending tests where I think I should use contact surface to model the geometry of the bending machine tool's head. In Optistruct I used slide contact before, but it didn't work to well because of large displacement. Is it possible the handle open gap contact and make the 3-point/4-point bending in Optistruct?
If you have any model for bending and tension and compression could you share with me? I would like to study the pre-process method to understand the nature of the coupon test in Optistruct.
Thank you for your help and advise in advance!
Best regards,
Tüki
I will check and get back to you ASAP... But I don't think OptiStruct supports non-linearity for material for Ortho material types.
You can prefer RADIOSS for this.
On 2/1/2018 at 7:21 AM, Prakash Pagadala said:
Hi Prakash,
Thank you for your support and help.
Is it possible to apply displacement for load in Optistruct?
In RADIOSS I saw a tutorial for 3-point bending so it would be perfect for me but later I want to use my material card to calculate some linear static problem on more complex composite structure. That's why I would like to use Optistruct in first place.
Is it recommended to use RADIOSS for material card validation/creation and use that material card in Optistruct? What do you think the overlap of these two solvers?
Thanks for your help in advance!
Best regards,
Tüki
