Hossein12345
How change the Element Type and Order in Hypermesh
Hello ,
I want to change 2. Order Elemets to 1.Order Elements in Hyper Mesh, I did it and export this new Model.
when I open this model(1. Order Elements) in Hypermesh, the Elements are not shown.
I tried to change the Element Type from SOLID187 to SOLID72 but, even at this time the Elements are not displayed.and the Elemet Types are still SOLID187.
my perpose is that I have to Run the new model(with 1.Order Elements) in Ansys, but with this Problem, ansys don't Run.
could you please tell me how can I solve this Problem?
Thanks Sanjay,
I did this , but the Problem is that, when I change the Order and export it, and want to open it again, these Elements don't shown.
for solving this Problem I change the Element Type.(SOLID187 to SOLID72)and change the Order, and export the Model, but again when I open it, These Elements are still SOLID178 and dont shown.
I think we have to find a specific way to change the Element Type, that saved in Model.with regular wayis not Possible.
thanks for your helping
before changing the order the element type is TETRA10 , SOLID185 (Picture1),
I change the Picture1.thumb.JPG.e7de384a90086a8691457d6277773f94.JPG2. Order to 1.Order and the Element Type is Tetra4, SOLID45 (Picture2)
I export the model in .cdb file and open it again, the Model look like the above Picture, (Picture3) and the Element Type is still SOLID185.
but how it is possible ?!!!! thanks for your helping.
After changing the order type as stated in the below post
On 2/1/2018 at 10:44 AM, Sanjay Nainani said:
In HyperMesh go to "3D" page and there go to "order change" panel. This panel lets you change the order of your elements.
Please try this
Thankyou
In Ansys Solver go to Utility Browser and then to "ET Type"
There create a new ET Type
Assign the ET Type with Element type you want to change it to.
Then go in the model browser and select that ET Type in the "Type" field for the respective component.
Now Export your model.
Thankyou
can you please tell me now where is ET Type in Model Browse?!
Hello,I change the 1.Ordet Element Type to SOLID45 but its not Running in ANSYS.
the 2. Order Elemet Type was  SOLID187, to which element Type I have to Change in 1.Order?
Tetra10 = SOLID 187
Tetra4 =?
thanks for your Helping.
Tetra10 = SOLID 187
Tetra4 =?
SOLID164?
https://www.sharcnet.ca/Software/Ansys/17.0/en-us/help/ans_elem/Hlp_E_SOLID164.html
or SOLID45?
http://www.ansys.stuba.sk/html/elem_55/chapter4/ES4-45.htm
Hey, after changing your elements to 1st order (3D => order change ), you HAVE to :
  • Define a new "Sensor" for 1st order type element. I take SOLID45 as example
  • Define a new "Property" for SOLID45 type:
  • Update your 1st order component:
Here're my tests models:   ansys-1st_order.hm       ansys-2nd_order.hm
HTH
