tinh
Creating User Toolbars in HyperMesh
Hi B)
I made this package to help creating user toolbars:
It is useful for someone has many scripts and wants them to be available by one clicking on HM GUI
Please notice me if any bug occurs.
example:
Enter here to download:
Mrt and llyle like this
1 hour ago, Q.Nguyen-Dai said:
@tinh: Is there any possibility to install into user's folder instead of HM Installation folder?
Yes, there is. But at least we need to add a package index file in hm home as an entry point for auto-start, or you have to add source $tboptsfile to hmcustom.tcl, or source it each time open hypermesh
I will make an Installer that help to select user's folder to install tbopts, this is better than you have to make it your self
I updated it with an installer.tcl file. Just copy folder tbopts to your own location, open hypermesh and File>Run>Tcl/Tk Scripts to run Installer.tcl
folder .../hm/script need to be writable, because pkgIndex will be copied there
Hello Tinh,
I tried to use your script in my work enviroment, where I'm using multiple hmcustom files. I don't want (and cannot) modify most of them.
I would like to modify only the certain one. The one I've created and added (by appending the enviromental variable) myself.
I have managed to add "tbopt" script in this file manually (basing on your instalation scripts). Now i would like to make your script to modify only the certain hmcustom file in the process of adding toolbars and buttons. Can you show me the way?
Michal
Hi Mr. Tinh
The got the following error message while running add toolbar script.
tag name 'Undo-Redo' # must be alphanum should not contain any wildcharacters
    while executing
"::hwtk::istagvalid $tag"
    (object "::.tbopts.f1.lb" method "::hwtk::widget::HWListbox::add" body line 7)
    invoked from within
"# Compiled -- no source code available
error "called a copy of a compiled script""
    (procedure "p_mnuOptions_Invoke" line 1)
    invoked from within
    (in namespace inscope "::tbopts" script line 1)
    invoked from within
"::namespace inscope ::tbopts p_mnuOptions_Invoke"
    (menu invoke)
Hm version 2019.1
Thanks in advance
