ayris
How can I visualize data from .dat file ?
I'm working on a Finite Element Fortran code(it is not very common)  where the output results are in *.dat format; is there a way to visualize the results(stress,strain...) using Hyperview? knowing that I have the node coordinates, element connectivity and of course the results of stress and strain at each node(see the file attached).
if it is not the case, is there any other software that does the trick.
thank you very much
input.dat
output.res
First things first, thank you for your reply  Mr.Q.Nguyn-dai
could you show me how can i build and HWASCII output from my results? by the way, I am not very acquainted with Hyperview
Thank you in advance.
 u hit the nail on the head, that's exactly what i need  hhh very nice dude;);).
how can i convert my output file to .h3d? are there available materials about that?
I know that i've been asking questions all day:D
Rahul R likes this
Alot of work to make this H3D :)
  1. From your output.res => Extract nodes & elems information => make *.hmascii => Import into Hypermesh => Export to *.fem
  2. From your output.res => Extract results. In my test, I tested with nodal displacement of 1st step. => write to *.hwascii
(I used Perl as scripting programming language)
Run Hyperview:
  1. Open *.fem as "model"
  2. Open *.hwascii as "result"
When you have all within Hyperview, you can export again into H3D format.
Rahul R likes this
Dear Mr. Q.Nguyen-Dai,
Hope you are doing great,  I have some issues concerning the topic we discussed earlier and I hope you can assist me with the matter;  could you please provide me with a video describing in details the method you used to create the mesh from the data file as well as visualizing results using Hyperview.
thank you for your time and I look forward to hearing from u soon.
best regards.
