tehran
b
did you try to change the type of solver?
To do it:  Solving >>  solving process options : edit >> linear system solver, change the type of solver (for example put MUMPS instead of ICCG)
Can you send us your Flux project.
Best regards.
1 minute ago, Flux support said:
Thanks for the file. I will keep you informed.
Best regards.
how can I get" jiles -atherton coef app.exe"?i have student version and i dont have any access to customer ftp to get that.
30 minutes ago, Flux support said:
find attached the Jiles-Atherton model.
Jiles.zip
in hysteresis loop model in flux, with only 5 parameters we have all loop(in any BH curve) or we have only on loop?
11 minutes ago, Flux support said:
About the number of loop, inside the model you have all loop.
In your case, I strongly recommend you to use the model with Flux 2D.
Best regards.
thanks for your response
I use 2D but there is still  problem
18 minutes ago, Flux support said:
HI,
it is the same probleme as before?
Send me your 2D project.
yes, i had.
i deleted it after i recognize that it is not convergence.
