Hi Vikas,
This is the sequence you should follow,
hwi OpenStack
hwi GetSessionHandle session_handle
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetScaleCtrlHandle poIScaleCtrl_handle
poIScaleCtrl_handle SetAnimationSource Displacement
poIScaleCtrl_handle SetInterpolationScaleMode model_percent
poIScaleCtrl_handle SetScale "5.0"
hwi CloseStack
Refer to https://altairhyperworks.com/hwhelp/Altair/2017/help/hwdref/hwdref.htm?poiscalectrl_class.htm for different parameters,
Livil Lyle
Dear Livil,
Thanks for your support actually i was using
Quote
"poIScaleCtrl_handle SetInterpolationScale model_precent" at the place of "model_percent poIScaleCtrl_handle SetInterpolationScaleMode model_percent"
as mentioned in syntax from help menu. So it was giving error.
SetInterpolationScale – Sets the scale mode.
SYNTAX
TYPE
HyperView Tcl Modify
DESCRIPTION
This command sets the scale mode.
mode
The scale mode.  Options include:  scale, model_units, and model_percent.
ERRORS
Returns 0 if successful, otherwise an error code.
I am very new in this field so i was not understanding the problem. Thanks alot .
Thanks,
Vikas Kumar
