ChristopheThen
shells on interior solid faces
53 minutes ago, Sanjay Nainani said:
To extract shells from 3D solid elements go to "Tools>>Faces". Here select the component and click "find faces". This will extract the 2D elements and place them in a new component.
Thankyou
Your method does NOT create interior solid faces.
yes it does. you need to select "elements" from the drop down.
Please refer the attached example:
This is a hollow cube tetra meshed.
when you use the suggested option it will extract 2D shell elements as shown below.
Thankyou
Mr Q.NGUYEN-DAI wants to say about interior faces, not boundary faces
I have a templex to generate it, tcl can do also but may be slow. I will share later
Ansa has this function but hm not yet
Mrt likes this
a script to create interior faces is like this:
You can save it to a file, then bind it with a user defined toolbar button, then just 1-click to get faces, not 2 !
proc ::p_CreateInteriorFaces args {
    if {[string match -nocase display* $args]} {
      *createmark elems 1 displayed
    } else {
	  *createmarkpanel elems 1 "Select 3d elems:"
    if {[hm_marklength elems 1]==0} return
	*createmark elems 2 "by config" tetra4
	*markintersection elems 2 elems 1
	set Buf *ELEMENT_SHELL\n
	set i 0
	set ElemList {}
	if {[hm_marklength elems 2]} {
		eval lappend ElemList [hm_getmark elems 2]
		set ElemNodes [join [hm_getvalue elems mark=2 dataname=nodes]]
		foreach {n1 n2 n3 n4} $ElemNodes {
			append Buf "[incr i],CompId,$n1,$n2,$n3\n"
			append Buf "[incr i],CompId,$n1,$n2,$n4\n"
			append Buf "[incr i],CompId,$n2,$n3,$n4\n"
			append Buf "[incr i],CompId,$n3,$n1,$n4\n"
	*createmark elems 2 "by config" penta6
		foreach {n1 n2 n3 n4 n5 n6} $ElemNodes {
			append Buf "[incr i],CompId,$n4,$n5,$n6\n"
			append Buf "[incr i],CompId,$n1,$n2,$n5,$n4\n"
			append Buf "[incr i],CompId,$n2,$n3,$n6,$n5\n"
			append Buf "[incr i],CompId,$n3,$n1,$n4,$n6\n"
	*createmark elems 2 "by config" hex8
		foreach {n1 n2 n3 n4 n5 n6 n7 n8} $ElemNodes {
			append Buf "[incr i],CompId,$n1,$n2,$n3,$n4\n"
			append Buf "[incr i],CompId,$n5,$n6,$n7,$n8\n"
			append Buf "[incr i],CompId,$n1,$n2,$n6,$n5\n"
			append Buf "[incr i],CompId,$n2,$n3,$n7,$n6\n"
			append Buf "[incr i],CompId,$n3,$n4,$n8,$n7\n"
			append Buf "[incr i],CompId,$n4,$n1,$n5,$n8\n"
	if {$i} {
		eval *createmark elems 1 $ElemList
		*findfaces elems 1
		if {[hm_entityinfo exist comps ^interior_faces -byname]} {
			*createmark elems 1 "by comp name" ^interior_faces
			if {[hm_marklength elems 1]} {*deletemark elems 1}
		} else {
			*collectorcreateonly comps ^interior_faces "" 4
		set Buf [string map [list CompId [hm_getentityvalue comps ^interior_faces id 0 -byname]] $Buf]
		set fpt [open interior_faces.k w]
		puts $fpt $Buf
		close $fpt
		*createstringarray 2 "LsDyna " "Keyword971 "
		*feinputwithdata2 "#ls-dyna\\dynakey" interior_faces.k 0 0 0 0 0 1 2 1 0
		*createmark elems 2
		*elementtestduplicates elems 1 2 2
		if {[hm_marklength elems 2]} {*deletemark elems 2}
		*createmark elems 1 "by comp name" ^interior_faces ^faces
		*createmark elems 2
		*elementtestconnectivity elems 1 2 2
		*facesdelete
	*clearmarkall 1; *clearmarkall 2
#example: create interior faces for displayed 3d elems
::p_CreateInteriorFaces displayed
Mrt likes this
it was metaphor:D i have been using BETA CAE for a long time, i really like it.=) But in my new job i have HW products.)
But i will test your script later=)
thanks.)
tinh likes this
hello, @tinh!
i have added your tool to user botton
but i didn't choose elements. is it normaly?
and i want to ask you.
how to move this tools to user botton. it will be conveniently to work.)
when i work with mesh it's uncomfortable to switch between geom/2dmesh/tools.
thanks.
image.thumb.png.11fa7eeacbffd3f12cb9dfee0d822f99.pngimage.thumb.png.8f710d0f51b38b8fb2bf03067d451dcc.pngimage.thumb.png.4a13b1f0618cf45ee9b2a51d446af2a4.png
Hi
Please remove "displayed" at the last line. Then it will prompt you to select elems
#example: create interior faces for  3d elems by user selection
11 minutes ago, tinh said:
And to add the panels to user button,
 set command for the button as
hm_pushpanel "panel name"
Wow!
i'll try! it will be useful to me!
i can add only tool from tcl scripts box.
but i can not add toolbox that contain all tools.
example.
i have added midmesh.tcl
but has added only midmesh create tool.
i haven't got editor and rebuild tool.=(
Hi
3D---> detach all elements (not detach from, simply detach) ---> take faces for detached elements, now give equivalence to all detached elements (shift +F3), now F10 ---> 2D --> Duplicates--> save failed
Create new collector in model browser --> organize all the saved elements in the new collector by using 'retrieve elements'
tinh likes this
On 8/9/2018 at 10:51 AM, tinh said:
    } else {
	set i 0
	set ElemList {}
	if {$i} {
		*findfaces elems 1
		} else {
		puts $fpt $Buf
		close $fpt
		*createmark elems 2
		*createmark elems 2
		*facesdelete
I am a new user in Hypermesh, and trying to learn how to extract shell from solid face.
When I tried to add new user toolbar in Hypermesh 2019, there is no choice of "options" in toolbars. Could you please help me to address this problem and show me a better way to extract the shell from solid face in Hypermesh?
Many thanks!
