Sign in to follow this
Hi to everybody,
i have this problem and i hope that someone is able to help me please.
I want to perform the stress analysis of some bodies connected to each other  and belonged to an assembly (the assembly is a wheelchair moving on the street) , but the stress only of those bodies not of the whole assembly. I saw that one way is using flex body to model the bodies, and it's the only way that i know to check the stress in motionsolve, but it happened this error:
ERROR: Error encountered in analysis!
(1) The integration has become unstable. Tighten (decrease) integr_tol, h_max,
or both in Param_Transient can help stabilize the integration. If the simulation
contains distinctive phases, use multiple Simulate, each with its
own proper integrator parameter setting, to selectively tighten the tolerance
during the period where instability is encountered.
(2) If the simulation was terminated because stepsize has diminished consistently
below h_min, reduce h_min in Param_Transient to force integration to continue.
(3) Non-physical inertia properties, such as mass=100 Kg and Ixx=Iyy=Izz=1 Kg*mm^2,
or extremely small inertia on a part with an unconstrained degree of freedom.
Make sure the modeling data, in particular the part inertia and the gravity, are
specified in proper units consistent with the units given in Param_Unit element.
(4) Beam, flexible body goes out of linear range, bushing has large rotation along
more than one axis, curve goes out of its interpolation range, higher-pair joint
goes out of the range of U or V, etc. Make sure fundamental modeling assumptions,
such as rigid contact assumption used in Force_Contact, are not violated.
(5) Motion displacement defined using LINSPL, AKISPL in dynamic analysis, or as a
function of model states (DX, VX etc), as well as forces defined as a function of
other forces, can cause hard convergence and integrator failure. Avoid these
modeling practices wherever possible.
has anyone some suggest?
or is there another method to check the stress analysis in motionsolve,maybe without using flex body?
thank you very much
