Hello to all,
I'm trying to model a wheel that rotates on a plane without slipping, but that can lift off the floor when it's needed. I used the contact command and Poissoin's algorithm, but I wonder if there is another way to do it. Is it necessary to write a subroutine?
thank you
Hi @FP90
You can refer to MotionSolve help. Here is a sample for GCON which is available on help:
Example
1. Three GCONs that together are equivalent to a spherical joint.
# Get the ids of the I and J markers
iid  = imrkr.id
jid  = jmrkr.id
# Create the expression strings
strx = “dx({i},{j})”.format(i=iid, j=jid)
stry = “dy({i},{j})”.format(i=iid, j=jid)
strz = “dz({i},{j})”.format(i=iid, j=jid)
# Define the 3 GCONS: DX(I,J)=0, DY(I,J)=0, DZ(I,J)=0
gx   = Gcon (function=strx, i=imrkr, label=”X-Constraint”)
gy   = Gcon (function stry, i-imrkr, label=”Y-Constraint”)
gz   = Gcon (function=strz, i=imrkr, label=”Z-Constraint”)
