Sign in to follow this
KevinE
Negative Area: Delete Connection Solid Element
Hi all,
towards the end of my simulation I'm always getting multiple errors regarding a negative area in some elements.
156100  0.1231      0.9462E-07 NODE   100000250 -81.9%   5593.       6745.       0.000      0.6832E+05   0.000
     NEGATIVE AREA: DELETE CONNECTION SOLID ELEMENT  100021614
     NEGATIVE AREA: DELETE CONNECTION SOLID ELEMENT  100017264
156200  0.1231      0.9419E-07 NODE   100000250 -82.0%   5595.       6736.       0.000      0.6838E+05   0.000
What does this mean and how can I avoid this error? I'm attaching my .out files.
Kevin
Test2_0001.out
Test2_0000.out
It is likely a connection element that is getting very compressed in your model.
You can check the behavior of these elements in the model.
