Sign in to follow this
rsoltany
I need a VTK format for my mesh
Hi,I am going to work with Fenics to run my problems. Actually, we should have vtk format for my meshes to run Fenics. There is 2 formats for vtk, one is vtp where it is for surface mesh and another format is vtu for volume mesh. I need a code for exporting my mesh to this formats. And for every surface I need a vtp outcome. For example, if I have 10 surfaces, and one volume, I need a code to give me 11 files, 10 files for each surfaces, and 1 file for my volume. Does it make sense? I could pay for this code who want to write it.
I see,
so the surface is formed by triangle elements? and each of them has 6 node (3 vertices and 3 mid-points)?
it is tria6 element type in Hypermesh, isn't it?
I found it,
the offset field will define type of poly, if it is shifted by 3 => it is triangle element
But I am stuck with connectivity field, it doesn't refer to global node ids but indices
and searching how can we generate the indices
I wrote it. Below proc will help to export vtp, a template is not neccessary.
example running it from command window of hypermesh:
p_Export2DToVtpFile MyModel.vtp all; #export all 2d elems
p_Export2DToVtpFile MyModel.vtp displayed; #export only displayed 2d elems
proc p_Export2DToVtpFile {FilePath {displayed_or_all displayed}} {
	*createmark elems 1 $displayed_or_all
	*createmark elems 2 "by config" tria3 quad4 tria6 quad8
	*markintersection elems 1 elems 2
	set ElemList [hm_getmark elems 1]
	set ElemNodeList [join [hm_getvalue elems mark=1 dataname=nodes]]
	set ElemNodeCount [join [hm_getvalue elems mark=1 dataname=nodecount]]
	set CompList [hm_getvalue elems mark=1 dataname=collector.id]
	eval *createmark nodes 1 $ElemNodeList
	set NodeList [hm_getmark nodes 1]
	set CoordList [join [hm_getvalue nodes mark=1 dataname=coordinates]]
	set _NodeList [lsort -integer $NodeList]
	set MinNodeId [lindex $_NodeList 0]
	set MaxNodeId [lindex $_NodeList end]
	set _ElemList [lsort -integer $ElemList]
	set MinElemId [lindex $_ElemList 0]
	set MaxElemId [lindex $_ElemList end]
	set NodeCount [llength $NodeList]
	set ElemCount [llength $ElemList]
	set Buffer {<VTKFile type="PolyData" version="1.0" byte_order="LittleEndian" header_type="UInt64">}
	append Buffer \n {   <PolyData>}
	append Buffer \n {      <Piece NumberOfPoints="NodeCount" NumberOfPolys="ElemCount">}
	append Buffer \n {         <PointData Scalars="GlobalNodeID">}
	append Buffer \n {            <DataArray type="Int32" Name="GlobalNodeID" format="ascii" RangeMin="MinNodeId" RangeMax="MaxNodeId">}
	set Buffer [string map [list NodeCount $NodeCount ElemCount $ElemCount MinNodeId $MinNodeId MaxNodeId $MaxNodeId] $Buffer]
	append Buffer \n $NodeList
	append Buffer \n {            </DataArray>}
	append Buffer \n {         </PointData>}
	append Buffer \n {         <CellData Scalars="ModelFaceID">}
	append Buffer \n {            <DataArray type="Int32" Name="GlobalElementID" format="ascii" }
									append Buffer "RangeMin=\"$MinElemId\" RangeMax=\"$MaxElemId\">"
	append Buffer \n $ElemList
	set _CompList [lsort -integer $CompList]
	set MinCompId [lindex $_CompList 0]
	set MaxCompId [lindex $_CompList end]
	append Buffer \n {            <DataArray type="Int32" Name="ModelFaceID" format="ascii" }
									append Buffer "RangeMin=\"$MinCompId\" RangeMax=\"$MaxCompId\">"
	append Buffer \n $CompList
	append Buffer \n {         </CellData>}
	append Buffer \n {         <Points>}
	set _CoordList [lsort -real $CoordList]
	set MinCoord [lindex $_CoordList 0]
	set MaxCoord [lindex $_CoordList end]
	append Buffer \n {            <DataArray type="Float32" Name="Points" NumberOfComponents="3" format="ascii" }
									append Buffer "RangeMin=\"$MinCoord\" RangeMax=\"$MaxCoord\">"
	append Buffer \n $CoordList
	append Buffer \n {         </Points>}
	append Buffer \n {         <Polys>}
	append Buffer \n {            <DataArray type="Int64" Name="connectivity" format="ascii" }
									append Buffer "RangeMin=\"$MinNodeId\" RangeMax=\"$MaxNodeId\">"
	#append Buffer \n $ElemNodeList; #oh, it doesn't refer to global node ids but indices
	set i -1
	foreach NodeId $NodeList {
		set Index($NodeId) [incr i]
	set Indices {}
	foreach NodeId $ElemNodeList {
		lappend Indices $Index($NodeId)
	append Buffer \n $Indices
	set Offsets {}
	set InitOffset 0
	foreach NodeCount $ElemNodeCount {
		lappend Offsets [incr InitOffset $NodeCount]
	set MinOffset [lindex $Offsets 0]
	set MaxOffset [lindex $Offsets end]
	append Buffer \n {            <DataArray type="Int64" Name="offsets" format="ascii" }
									append Buffer "RangeMin=\"$MinOffset\" RangeMax=\"$MaxOffset\">"
	append Buffer \n $Offsets
	append Buffer \n {         </Polys>}
	append Buffer \n {      </Piece>}
	append Buffer \n {   </PolyData>}
	append Buffer \n {</VTKFile>}
	*clearmark nodes 1
	*clearmark elems 1
	*clearmark elems 2
	set fpt [open $FilePath w]
	#fconfigure $fpt -encoding utf-8
	puts $fpt $Buffer
	close $fpt
	set FilePath
