I don't think command recorder is anymore needed. For Altair Hypermesh 14 and above command.tcl saved in working directory (mostly in Documents) does the needed job.
14 hours ago, Q.Nguyen-Dai said:
Which version of Hypermesh do you use?
"command.cmf" is OLD release.
HI
I use version 2017
Hello
Could u please tell me more about that! Does it means every command in HM saved after we save that file?
1 minute ago, pohan said:
Hello
It keeps a track of all the operations you're doing in HM. It saves automatically in background.
Thank you Livil Lyle
In my opinion, sometimes if we want to focus on some specific commands may be command recorder is better.
It is not a problem with me. I usually delete command.cmf before I focus on a certain command.
the recorder is actually unnecessary
if i want to track it, I will set a tracer
Hello
I create my first tcl/tk script file with the syntax like that
*startnotehistorystate {Deleted Components}
*createmark components 1 " RW_left" " RW_right" "Compresseur"
*clearmark components 1
*deletemark components 1
*endnotehistorystate {Deleted Components}
in order to delete component " RW_left" " RW_right" "Compresseur" in my model.
But when I run the tcl/tk script file it did not work.
Could you please give me some suggestions?
Thanks
Hi
try removing space in front of comp names
you have excessive createmark and clearmark commands at line 2 & 3, they are unnecessary.
1 hour ago, tinh said:
Hi
Hi
I tried but It said that
invalid command name "*startnotehistorystate"
    while executing
"*startnotehistorystate {Deleted Components}"
    (file "D:/Dropbox/Lille/Altair/TCL/Hoan/command03_15_delcomp.tcl" line 1)
    invoked from within
"source {D:/Dropbox/Lille/Altair/TCL/Hoan/command03_15_delcomp.tcl}"
    ("uplevel" body line 1)
    invoked from within
"uplevel #0 "source {$file}""
    (procedure "::HM_Framework::p_FileLoad" line 68)
    invoked from within
"::HM_Framework::p_FileLoad 24"
    (menu invoke)
Hi Pohan,
You don't need startnotehistorystate and end endnotehistorystate. All you have to do is:
*createmark components 1 "RW_left" "RW_right" "Compresseur"
Hi Tinh and Livil
Thank you very much. It worked with two rows.
I think  startnotehistorystate and end endnotehistorystate are for undo.
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
