Hello everyone
Can someone give me an advice on how to indicate that a certain surface have a temperature of 20°C and another surface of 80°C? And also indicate the pressure of those surfaces? In order to get thermal and mechanical results of it?
I thank you in advance for your help!
You can apply temperature using Analysis>> Temperature in a separate load collector and apply pressure with a separate load collector.
Goto loadstep panel>> refer pressure load collector for load>> Edit the loadstep and find TEMP_LOAD and refer Temperature load collector here.
Sign in to follow this
