Novak
Hypergraph
Hello Everyone
I have made a dogbone shape for tensile test analysis. Since the material is anisotropic, I used converse software to map the fiber orientation. As you can see in the model attached, on one side of the dogbone, there is a rigid, in which master node(1) is completely fixed and on the other side there is enforced displacement on the master node(2).
I want to create a graph where I obtain displacement of the master node(of the displaced side, 2) vs. reaction force of the other master node(fixed side, 1). I am doing a non linear quasi static analysis.
First, I tried to plot displacement vs time and that functions looks correct but reaction force vs time graph gives me just a point. I don't understand why it just shows a point and not a line like it does for 'displacement vs time' graph. I was planning to do cross plot once I obtain the reaction force vs time graph.
Some additional information: master node on the fixed side has id number: 7833 and master node on the displaced side is 7834
Would appreciate any help
Thanks in advance
positioned_final_delete_cof_new.fem
positioned_final_delete_cof_new.h3d
Hi Vivek
Thanks for the answer. However, it doesn't seem to work. Initially in my file, under Y-request I had the option to select the node ID (see attacehd screenshot 1). But now with your files, I don't see that option anymore. It just says 'dummy' under Y-request (see attached screenshot 2)
Thanks
Hi Vivek
It works great. Thanks a lot Vivek. Appreciate your help.
Just couple more things.
1.) What did you change exactly?
2.) Why doesn't it work in hypergraph?
Thanks
Sincerely
Jaivin
HI Jaivin,
Incremental outputs of SPCF is not supported for small displacements, please add PARAM,LGDISP,1 to get incremental results of SPCF.
I am able to get the curve in HG too, please use the latest version i.e. v2017.2
Thanks
Vikas
Hi Vikas
Thanks again vikas. However, I am using hypergraph 2017.2 version but under Y-request, I only get an option of 'dummy'. I don't see how can I select the exact node ID which I want.
Thanks
Sincerely
Jaivin
