Hi all,
Is there any possibility  to create beam2n in Radios?
Because there is beam3n at everywhere and when i use beam3n in my model, beam element aligned error occurs. What should i do to solve this poblem ?
Thanks in advance.
For RADIOSS the element type for beam is Beam3n. The 1-2 node define element geometry, the 3 node defines the cross sectional orientation.
Please ensure the orientation is correctly defined so that you can sort out this error.
