Good Afternoon.
Optistruct solver fetches me great result for a non linear quasi static analysis ( non linear solution converged). But when I run the same file with a coupled topology optimization I get error 941: non convergent non linear iterations for subclass 2. Feasible design <All constraints satisfied>
Why is this happening and how do I resolve it??
thank you.
Kindly check the attached .out file.
I have now increased the number of iterations to 50 and put the run. i am awaiting results, though my intuition says it might not converge as well. I have also tried creating shell elements for the same model and tried solving it but to my surprise it wouldn't even go this far as the attached file. it would always readjust its convergence criteria and solve but would fail eventually.
Kindly let me know where am i going wrong.
ice server non linear static solid opti_007.out
Good Evening.
I have attached the most recent .out files. Kindly go through these files and let me know where i am going wrong. One of the files is for the solid model and the other one is for the shell of the same model/component.
I have also turned on ISOP for PSOLID but to my bad luck it didn't work out as well.
Kindly help me in resolving the issue.
Thank you.
ice server non linear static solid opti.out
ice_server_non_linear_static_shell_optimisation.out
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
