Saeideh
force-displacement curve
Hi
I have a pipe with non linear material , internal pressure and a force  end of pipe , 2 load step, at the first step I have only internal Pressure and in second load step,Pressure+ Force. I have defined the force as pressure. after analyse I want to get force- Displacement (force end of pipe  as pressure ) . I need force-time and displace-time curve but I have only one time . I need many time to get curve. what should I do?
Best regards
S.Faghfouri
If you are using Altair OptiStruct or Radioss solver,then you can use .h3d file to plot curve.For other solver, please use a file which contain this output.Please share the solver used for analysis.
hi . i share my file. could you please make for me a force displacement curve for subcase 1 and 2 ? as a result I have to get  following diagram :
thank you.
Hi @Saeideh
I am not clear about the analysis and also solver.
I see /RUN card in the model but works with OptiStruct. Please clarify.
Quote
hi,
thank you mr Pagadala for your answer.
it is so:
at the first, there ist only an internal pressure of p=2.5 Mpa ( this pressure with a load scale can increase ( incrementally) up to 2.5 Mpa).  now i have pressure (p=2.5 Mpa) and I have to bring  an axial force (increases incrementally) at the end of pipe up to welding area is plastified.   ( as a figure - this force is defined hier as a pressure too) .
best regards
8 hours ago, Prakash Pagadala said:
Hi @Saeideh
hi,
it is so:
best regards
OK, thank you,
If you want to plot applied load Vs displacement, you can add OLOAD card to your model which outputs applied load.
