goncalop
Composite Wing Free Size Optimization
4 hours ago, goncalop said:
Minimizing mass with a constraint on the displacement was the first optimization I was doing and the results were completely erratic. That was why I switched to minimize compliance with the volume fraction constrained
Try this during the sizing optimization instead of free size for that particular laminate.
Regarding the thickness, I was aiming to give a maximum thickness to the laminate on that specific area. On the design variable menu you can choose the maximum or minimum laminate thickness but they are general thicknesses and I was looking for a local constraint... The thickness of the Plies could be whatever the solver wanted it to be as long as the thickness of the laminate would not exceed the given value...
You are right, laminate constraints are applied to the entire laminate.
As a workaround, you can define the local area/volume as a separate laminate and you can apply laminate constraint for that.
Hello @Prakash Pagadala, how are you?
I've been working on the model and getting some nice results. Splitting the design variables and constraining the zones where I want a defined thickness is indeed working.
Before I proceed to the size optimization I would like to get the ply shapes to something more manufacturable.
This is what I have right now:
Now, from what I read and from what you told me I have two options: I can either use OSSMOOTH or Ply Geometry Smoothening from the Aerospace Menu.
I've tried Ply Smoothening before but for some reason I can't get it to work as intended (it freezes or it doesn't create any .stp file) and I've been trying to work with OSSMOOTH and I think it is working to some extent (at least the number of plies is reducing).
Before I proceed I wanted to know if you could explain me better what each of the options does on each case:
OSSMOOTH:
Select Model - I select the .fem file for which I want to smooth the plies (on my case, I've used the result of the free size optimization)
Output File - OSSMOOTH will output a .fem file with the smoothed plies which I'll have to import to a model later
Smooth Iterations - How many times OSSMOOTH iterates each ply until the best shape is achieved?
Small Region, Area Ratio - The minimum area ratio for each ply? If I choose 0.4 the minimum ply area is 40% of the total area?
Split Disconnected - If a ply has more than one area that is not connected, it splits the ply in different plies for each zone
Create Geometry - ???
Ply Geometry Smoothening:
For this one I need a little bit more help. While OSSMOOTH writes to a different .fem file, this one works on the current .hm file.
I don't understand the geometry collector and geometry creation parts (where does it create the geometry?).
The smooth Iterations and small region I think work the same as in OSSMOOTH right? The same goes for split disconnected ply regions...
Update ply element sets I also do not know what it does.
Export surfaces and lines is self explanatory I think but I can't get it to work.. even with 0 iterations..
Sorry for such a lengthy post but I'm really trying to make a good project and I can't seem to find anything to properly answer this questions on the internet..
Thank you so much for your help!
Gonçalo Pimenta
I would go with default to start with and create geometry is not required unless you want to take the ply shape to any CAD tool. SPlit works on entire ply.
It creates either as a seperate component or a mixed geometry of all plies in the same component.
Hi @Prakash Pagadala,
Thanks for the swift reply.
I need to output the ply shapes to cad so I can create the ply geometries to use on the plybooks and to later cut the plies to layup on the mould.
This is why I need them with a nice shape.
When I select create geometry on OSSMOOTH it doesn't give me any option to create an stp file like on Ply Geometry Smoothening. How do I make it output the .stp file?
Thanks!
@Prakash Pagadala,
So, instead of going for OSSMOOTH, I go for Ply Geometry Smoothening for a few plies at a time while exporting the .stp files? With the default settings?
If I choose a area ratio of 0.4, what happens to the plies that have a area ratio smaller than the one I chose?
Also, the area ratio is calculated regarding the whole area of the model? Or the area of the original set?
Thanks!
Yes,
I need to check regarding this. I will get back to you on this.
So, if I have more than one design variable, the area is the sum of all the design areas?
In my case, the total area is the lower skin + rib + top skin?
I tried doing what you told me but it freezes and doesn't give me any results.
I tried running some tutorials and everything seems fine - for example, on OS-3400 I can get 20 to 400 iterations, different area ratios and I always get a result in no time.
With what I'm doing although, it takes a awful long time and it doesn't seem to do anything at all. Smoothening the plies is the last thing I have to do since the size optimization and shuffle optimization is possible (I've done it) but the plies shape is terrible for manufacture.
Do you have any advice in order to get it to run faster?
Thank you very much!
Gonçalo Pimenta
I sent you some files yesterday so you can check better with my fem.
Thank you for your help. I have a workstation available with a Xeon E5-1603 and 16gb of ram but the result is the same I guess...
I can try leaving it more than a day but I think that one day is already too long... When I press OK the result is the same as the one I sent you by file transfer. CPU and RAM usage, no disk writing and Hyperworks no responding.
Thank you for your help!
Gonçalo Pimenta
I ran some things today and I finally got results:
I first ran OSSMOOTH with 40 smooth iterations and a area ratio of 0.4. - Both split disconnected and create geometry were left unchecked.
Then I ran Ply Geometry Smoothening with a separate component for each ply, 0 Smooth iterations and the same area ratio as OSSMOOTH. I then checked update ply element sets and exported the surfaces to an .stp file.
The Xeon workstation managed to do this in 2 hours or so, so it's not so bad.
With this, I have a few questions:
1 - What is the true meaning  of area ratio and how it affects the final result
2 - Smooth iterations? The more I choose the smoothest my final ply?
3 - How can I get symmetric plies? See below, some of the plies created are not symmetrical even thought the load is a constant pressure
Also, how do I prevent small zones like the one below? I thought that was done with area ratio. Should I check split disconnected so it can clean them?
Thank so much for your help! I look forward for your feedback!
Gonçalo Pimenta
Glad that you are able to get the shapes, I am checking with experts on ply geometry tool.
The area ratio is the local patch area/ total area of the ply,
Though the load is symmetric, optimized results may not be symmetric. You can add symmetric pattern grouping constraint before you start the analysis.
Please refer to attached PDF for more information
Interpretation of Composite Free Sizing Optimization Results.pdf
Thanks for the reply!
I have two more questions:
1 - When I export the .stp from ply smoothening I sometimes get the plies perfeclty split up as shown now
And other times I get just three components where I can't distinguish each ply? Has this ever happened to you before?
2 - When I try to run a size optimization after the free size optimization it gives me the following error:
  *** See next message about line 256 from file: size.fem
   "STACK   4       SMEAR"
  *** ERROR # 1901 *** in the input data:
  STACK must have either a list of PLYs or substacking data.
Could this be because when I run ply smoothening of ossmooth it creates/deletes existing plies so I don't have enough or have too much design variables?
Thank you very much for your help!
I'll send the .fem and .out files so you can take a look!
Once again, thank you so much!
Gonçalo Pimenta
@Prakash Pagadala,
Just checked, after smoothening, stacks 4 and 5 don't have any plies on them. Do you have any idea why they are gone?
Do you think they are gone due to the area ratio value? Wasn't area ratio supposed to be related to the original ply size?
Only stacks 4 and 5 are gone, that are the design variables constrained to a maximum size.
They are the ones highlighted below:
Thanks!!
Gonçalo Pimenta
Thank you for taking the time to look at it!
In the meantime I've been running different iterations of OSSMOOTH with different area ratios and the result seems to always be the same which is odd.
So far, I've tried with .1, .2, .3, .4, .5 and .6 on the area ratio (and 40 iterations, with no geometry creation nor splitting) and I always get 28 final plies spread across 3 laminates.
The other two laminates that area the areas that I've limited to a maximum thickness now have no plies and their type is now "Interface Ply".They have an interface definition but they are empty.
I've also tried instead of OSSMOOTH just running Ply Geometry Smoothening but it doesn't seem to change much (with the same area ratios from OSSMOOTH) - While they both start with 50 plies to clean - OSSMOOTH always go to 28 plies while Ply Geometry Smoothening goes to 49 plies.
If you need any files, let me now!
Gonçalo Pimenta
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
