vigneshtamil
Restart file 1_0000.0001.rst was not created
Can you kindly help me with evaluating the result file. How do I get the .res files? Or how can I evaluate the results without that file.
Also, it would be of great help if you could help me with the procedure for adding or editing the FLC curve (forming limit curve) for the material. The tutorial says it has an option for FLC under the setup tool. But I could not find that option in the setup menu. I am using the Hyperform 2017 version.
Kindly help me as soon as possible.
Thank you again.
the Results of the forming is stored in *.sta file, which you can make as an input for the next stage of forming or for further Analyses.
To evaluate forming results you can check via animation files (  files with suffixes of A001, A002 and so on). Import the first file (A001) in Hyperview and check for results contour.
To see FLC of a material in Hyperview, follow these steps.
  • goto File>load>preference file> Hyperform utilities. you will see a new pull down tab of hyperform in the menu bar
  • now load the aniamation result file
  • choose FLD option from the hyperform tab
  • click on add button under FLD studies ( see image below)
  • enter values of strain hardening exponent 'n' and blank thickness to get FLC
  • you can now go to FLD to plot the graph.
Thanks for your reply. I tried the method as explained above. But when I click the FLD option after loading the animation result file in Hyperview, I am not getting any options regarding FLD. So I am not able to add the FLD Curve. I am using the Hyperworks version 2017.1.
Kindly help and thanks in advance.
I have pasted Images showing the procedure to view FLD in Hyperview. descriptions of the images are given below,
  1. after launching Hyperview, go to "load model" , browse for the animation files (either *.A001 file or *.h3d file). click apply once the file is selected
  2. ensure only the blank is visible (for ease of selection). go to the last time step and make sure the animation is paused at this stage.
  3. Load FLD options from either
  • from menu bar>tools> FLD OR
  • goto File>load>preference file> Hyperform utilities. you will see a new pull down tab of hyperform in the menu bar. select FLD
      4. click on 'add' . in the FLC tab, enter values of strain hardening exponent 'n' and blank thickness 't' and click apply. the Hyperview GUI window splits into two to show a  new plot on the Right side
      5. click on FLD tab, click on the 'components' and select the part visisble in the GUI, click apply.
Hope this helps
I am using hyperworks version 2017.1. In the hyperview, I am not able to import the model file. I am only able to import the session file in .mvw format. After importing the file, I have the option Tools - FLD. But when I click the option, I dont get any response. It is like the option is disabled in that situation. Kindly help me. Thanks in advance.
You need to browse for the file by clicking the icon next to the load model option ( as shown in the image below) and not by open model icon from the standard tool bar.
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
