Sign in to follow this
JAMIE
segmentation error
26 minutes ago, tinh said:
Hi Jamie
it is due to some of commands are sensitive to make appcrash
so tinh how can i overcome that...or what changes should i make
Hi Jamie,
You have to detect which command is output to command.tcl last? then the next command in your script is sensitive.
Please show us a range of your codes around that command
27 minutes ago, tinh said:
Hi Jamie,
the error appeared after you clicked on OK button of the message box, didn't it?
yes tinh
and the the exported file is not in proper format.
Hi Jamie,
the sensitive command is *findmark
I think the bit must not be 257
could you shift f5 and find some elems attached to some nodes then check what number is output to command.tcl?
as i remember, it is 1 or 0
13 hours ago, tinh said:
Hi Jamie,
tinh ,i dont find any difference in that command.
tinh ..anyway the commands above the findmark itself are not excuted.
On 4/23/2018 at 7:22 PM, tinh said:
Hi Jamie,
HEY TINH .got the issue solved.....There was  was no *createstringarray before the feinputwithdata command
tinh likes this
