Karthic
Contact Penetration in Sliding
As shown in GIF, facing penetration issue for surf to surf continuous sliding contact.
1. Tried changing the master and slave
2. Tried S to S and node to surface
3. Used Pcont,  tried stiffness value (1000 & 100000) , auto, soft & hard
4. Also tried changing material
5. Tried with Opengap, Norm
But still I couldn't correct the penetration issue
The fem file is attached to this. Please do help me with the issue.
trial-2.fem
Hi @Karthic
One more issue is that the green component is set with rigid and when the stiffness is set AUTO contact stiffness is calculated at a different stiffness.
Try to remove rigid and apply load on nodes of Green component and please check the results.
@Prakash Pagadala,
Thank you,
Either I should make it rigid or solid part. It cant be shell part.
what if I make the part as solid and still gets penetration....
Is it ok, can I have these penetrations
Or any other way to avoid the penetration, the model being solid or rigid
Hi @Karthic
I wrote to experts and waiting for their reply.
Usually, the penetration could be because of contact stiffness.
Have you tried with PCONT?
@Prakash Pagadala
Ya
On Saturday, April 21, 2018 at 8:21 AM, Karthic said:
Hi @Karthic
Can you try with NLGEOM and PCONTX7 where you can more control over contact stiffness (Istiff)?
Since contact stiffness is based on the stiffness of the components, you can also try to reduce the thickness and check if that helps.
