Sign in to follow this
alpha
Single action vs double action
Hi HF experts,
I am new to Hyperform and feel a bit difficult to understand the concepts - "Single action" v.s "Double" action in Hyperform.
Which cases should we use "Single" and when should use "Double"?
Hi single action and double action denotes the type of press.
  • Single Action Presses. A single action press has one reciprocation slide that carries the tool for the metal forming operation. The press has a fixed bed. It is the most widely used press for operations like blanking, coining, embossing, and drawing.
  • Double Action Presses. A double action press has two slides moving in the same direction against a fixed bed. It is more suitable for drawing operations, especially deep drawing, than single action press.
Thank you very much Ms. StuDes
