i tried to solve the Optistruct OS-T 1600 Tutorial, but after starting the two solvers (optistruct, acusolve) there is a convergence error of acusolve that stops the job:
Messages for the job:
 *** ERROR # 5202 ***
 Acusolve stops before FSI iteration achieves convergence.
 *** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
Does anyone knows the problem? I checked all steps of the tutorial and start it again, but the error still appears.
The next step was to change the exchange parameter of acusolve (min/max_stagger_iterations) and optistruct (min/maxEX) to 30. A Simulation of the Tutorial with only 0.02s worked.
To simulate the tutorial 0.1s or the whole 1s - as it is described in the Tutorial- still doesn´t work with a value of 100 for max_stagger and MAXEX. Another error appeared:
Does anyone has got experience with the tutorial OS-T 1600 and solved it successfull?
Thank you very much in advance.
@Prakash Pagadala
Hello Prakash,
I tried to built up an own FSI Problem and i got the same error as written April, 23.
What does this error generally means? What´s the problem?
*** ERROR # 3423 ***
 MUMPS solver encountered error with code -6.
 please contact support and provide .out and .stat files.
 *** INTERNAL PROGRAMMING ERROR ***
   in file "nltranend.F", at location # 364.
 ****  ABORTING RUN DUE TO AN INTERNAL ERROR  ****
Thank you in advanve.
FEM_001.out
FEM_001.stat
Hi
I want to do tutorial OS-T 1600 FSI but in creating contact surface, when I click on "0 elements > elements" I cannot pick all the faces of the beam. When I select all the faces nothing happens and if I click on add, the message "No new elements have been selected" appears. Could you please let me know how to select all the faces? Do I need to have "all shell faces" or "all solid faces"?
In fact I managed the problem. It needs to have "all solid faces" to select elements.
I think this is the problem...
*** WARNING # 9113
 It appears that the directory used for scratch files:
    /home/ac7754/fsi_slab_1/
 is located on remote filesystem.
 This could result in very slow solver performance.
   Number of CPU processors        :         32
If possible share the model file to debug...
On 8/3/2018 at 12:21 PM, Question said:
Hi Prakash
Please find the model file in attachment.
Thanks & regards
Slab.hm
Slab.fem
I am able to reproduce the same but with a different warning message, I will get back to you with more details ASAP
8 hours ago, Question said:
Hi Prakash
Do you have a copy of FSI_AS_MANIFOLD.inp and FSI_OS_MANIFOLD.fem, please?
Thank you.
Can you give me the reference to the document about the files?
Hi Prakash
Is it possible to look at attached file and let me know how to manage the problem, please?
It is OS-T: 1610 Thermal Fluid-Structure Interaction Analysis on a Manifold.
Thank you.
 ****  ABORTING RUN DUE TO UNEXPECTED ERROR CONDITION  ****
Error output from the solver:
External Code via CCI: *** ASSERTION in Function <cciNew> File <linux64/src/cci.c> Line <152>
External Code via CCI: *** Did not receive connection request from client after waiting for 2400 sec
hwsolver.mesg output from the solver:
optistruct:: Solver run finished after 40 minutes.
FSI_OS_MANIFOLD.fem
Hi Prakash
When I run both tutorials OS-T 1600 and 1610, there is the following error.
acuSolve: *** ASSERTION in Function <ecdSetFatalError> File <ecd.c> Line <4208>
acuSolve: *** unable to match with external surface at 7 quadrature points
acuRun: *** ERROR: error occurred executing acuSolve
Could you please let me know how to manage it?
Thank you.
Hi Prakash
I want to run an implicit simulation on a model with around 6 million elements. I set up the simulation as plate model in implicit analysis. However there are the following errors in my run. How can I solve that problem, please?
 *** ERROR # 4002 ***
 Running RADIOSS engine, 1 ERROR and 0 WARNINGs have been detected.
 ANALYSIS COMPLETED.
 *** SOME ERRORS WERE REPORTED DURING THE RUN,
 *** PLEASE VERIFY RESULTS AS THEY MAY BE INVALID.
  A fatal error has occurred during computations:
  ANALYSIS COMPLETED.
Errors reported during program execution
 ANALYSIS COMPLETED.
Solver FAILED
optistruct:: Solver run finished after 2 hours (10117 seconds).
Thank you.
Hi
It is a NLGEOM implicit static analysis as you did for a plate. I set up my model as the plate one. The plate model is in attachment.
Is NLSTAT with LGDISP different than NLGEOM one, please?
Thank you.
plate_imp.fem
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
