Sign in to follow this
baozaizhang
Generate OP2 file
10 hours ago, tinh said:
Hi
in panel analysis>control card
you activate card named OUTPUT then select  its keyword as OP2
Hi, Tinh:
Thank you very much for your help. Every time when I got a question, you replied me very quickly. I got a follow up question about moving things in AcuSolve. If I need to move the red block to the place of the grey box, and to make sure the left-bottom points are at the same location after moving. May I ask if there is a way to do it? Just like moving blocks in AutoCAD using reference points.
Thank you.
Hi
Hi, Tinh:
i got it. I can use "position" to do it. Thank you.
tinh likes this
