Sign in to follow this
Arul
Time step error
I am facing the following issues with Radioss run - Quasi Static analysis.
1)  Without /DT/INTER/DEL in Engine file , the run has been stopped due to min time step error.
2) With /DT/INTER/DEL in Engine file the mass scaling DM/M  is increasing gradually till 30% from 3.2%
Let me know for comments to avoid this error
Arul
The interface is creating issue in your case. I presume there are penetrations in your interface, check and correct the same. You can try also with a small Gapmin value.
With /DT/INTER/DEL check in HyperView how the simulation works, and also what causes for time step drop. Remove/DT/NODA for this case and run.
