Punith
Press fit analysis
Hi Nachiket,
I think the solver has to perform the iterations until the full  load is reached. But since 15 hours it is in the same 92% load iteration. No Increment in the load. What is the problem?
Thanks and regards,
Punith
1 minute ago, Punith said:
Hi Nachiket,
Thanks and regards,
Punith
@Punith Never encountered such a problem. How much time it took for the solver to reach 92%?
@Prakash Pagadala
ok I understand that. Thank you for the reply.  Now to avoid such a mistake next time how can I export the intermediate results. For example the solver has performed the iterations upto 92% load now and looking for convergence. But I would like to see my results at 91% load. How can I do that?. Please help me.
6 minutes ago, Punith said:
@Prakash Pagadala
To view previous iteration you can use NLOUT.
Yes, you can still use NLOUT and also you use NLMON to monitor Nonlinear simulation
10 minutes ago, Punith said:
But NLOUT is already used in the model. I do not see any H3d file in the location.
For that in control card you need to switch NLMON=Disp.
As far as i remember NLOUT= write last non convergent file
and NLMON= write all iteration in seperate H3D
Correct me @Prakash Pagadala if i am wrong?
@Prakash Pagadala
I have a question regarding axisymmetric analysis. Is there any option available in Hyperworks for axisymmetric problem like in Abaqus?.If not, is Hyperworks working on that?.
I have a cylindrical component andI would like to mesh only 2D crosssection of it and finally see the results for 360 Degree. How can it be done?. I tried defining the symettric constraints for the 2D mesh and defined the line contacts between the mesh. But it is not working. I contacted Hyperworks-Germany support team and they said that line contact is not working with Optistruct. How can I solve my problem? I am not able to work with 3D model as it is taking lot of time. Please help me in this concern.
I am basucally looking to some parameter study for pressfit analysis of rim and disc by varing the length of press fit and angle and I am looking for the optimum. I think this problem can be handeled in Hyperstudy. This problem is non-Linear and if I work with 3D it takes huge time.
Punith
Hi Punith,
Is it possible to share the axisymmetric problem from Abaqus (PDF should do)?
I will check if I have any information.
Hi Punith,
This is possible in RADIOSS
Here is a reference: RD-E: 0800 Hopkinson Bar
Hello@Prakash Pagadala ,
I am just asking about the file for the Hopkison Bar as the example requires the input file.
Input File
High_strain_rate: <install_directory>/demos/hwsolvers/radioss/08_Hopkinson_Bar/High_strain_rate/SHPB_H*
Low_strain_rate: <install_directory>/demos/hwsolvers/radioss/08_Hopkinson_Bar/Low_strain_rate/SHPB_L*
Thanks!
