Sign in to follow this
Girish2121
Add Browser Tabs
Hey Tinh and others as well,
Thanks for helping everyone in the field of automation.
I have query which is extended version of above query
Since, I had already developed a GUI using tab feature. But, due to its use on another machine (with changed screen resolution), the buttons at bottom are hidden. So I decided to add scrollbar. But no success.
Earlier My code was this -
    catch {hm_framework removetab "Test-Group A"
    destroy .main}
    set main [ frame .main ]
    hm_framework addtab "Test-Group A" $main
    hm_framework resizetab "Test-Group A" 440
    frame $main.main_frame -height 550 -width 450 -bg "#C5E1A5"
    grid $main.main_frame -row 0 -column 0 -sticky w -padx 0 -pady 0
        image create photo imgobj0 -file "$::script_address\JarFiles/Image/Test_Logo_222.png" -width 450 -height 130
        label $main.main_frame.label0 -bg "black"
        grid $main.main_frame.label0 -row 0 -column 0 -sticky w -padx 0 -pady 2 -columnspan 2
        $main.main_frame.label0 configure -image imgobj0
... and so on (includes Labels, entries, buttons in vertical layout)
After implementing scrollbar and related parent frame, canvas and child frame-
    destroy .main}
    set fmain [ frame .main ]
    hm_framework addtab "Test-Group A" $fmain
    #set up scrollable frame
    set frmparent [frame $fmain.frmparent -width 450 -height 500 ]
    set canvas1 [canvas $frmparent.canvas1 -width 553 -height 600 -xscrollcommand "$frmparent.hscroll set" -width 523 -height 500 -yscrollcommand "$frmparent.vscroll set"]
    set main [frame $canvas1.frmscrolled]
    # package require BWidget
    # ScrollableFrame $frmparent
    # set frmscroll [$frmparent getframe]
    set hscroll [scrollbar $frmparent.hscroll -orient h -command "$canvas1 xview"]
    set vscroll [scrollbar $frmparent.vscroll -orient v -command "$canvas1 yview"]
    pack $frmparent.hscroll -side bottom -fill x
    pack $frmparent.vscroll -side right -fill y
    pack $canvas1 -expand yes  -side top
    $canvas1 create window 0 0 -anchor nw -window $main
    $canvas1 configure -scrollregion [$canvas1 bbox all]
    pack $frmparent -expand yes -fill both -side top
But it seems to not work.
Thanks,
