akshay325
Composite with 3D Element (PSOLID)
I'm planning to use PSOLID element for a 3D composite model, but I'm stuck with how to put thickness, orientation and Failure theory. Please tell me how to go about this.
Thanks.
Hi @akshay325
Solid thickness will be the thickness of the ply and there is no thickness as such on PSOLID card.
You can review or assign orientation using Orientation tools or be using the systems panel.
You can use MAT9 or MAT9ORT as the material card for orthotropic material with solid elements.
On 6/4/2018 at 6:14 AM, Prakash Pagadala said:
Hi @akshay325
Dear Prakash,
If I am planning to use Solid elements for composites,  how is the distribution of the stacking of the laminates in the thickness of the model? Should I need to have the number of elements through the thickness of the model the same of the number of layers (and with the same thickness per layer per solid)? Or is HM automatically  assigning one element for each ply
Thank you for the time
