Wisawanart
ERROR : RUN NAME IS NOT DEFINED
Hi Support Team
      I have tried to run the simulation model including the residual stress (.sta). I set the stress into the model using Results Initializer from the Crash interface, unfortunately, I face MASSAGE ID : 194
ERROR : RUN NAME IS NOT DEFINED.
      Before the residual stresses are taken into account, the solver operates properly. Even though, I have already filled up all of blank which is related to "RUN NAME" but still fail.
How to fix this issue?
Best regards.
Wisawanart
