EmSt
error: no materials database
I wanted to increase my numerical memory in the options menu in Flux Supervisor. The following error massage comes: "no materials database defined" (see Picture).
But when I start a Project the database exists. So I don't understand why this error massage comes.
Does someone know what to do?
Thanks.
To increase the numerical memory in Flux you, in the option you select memory.
About, the error message, I Checked when I open the options >> Materials, I get any error message. But, in your materials database for import in Flux you have any link inside (see the attached picture). I think for this reason you get the error message.
Can you check if you have installed all the files correctly (see attached picture)?
If it not the case you will find attached the files. You need to load all the files.
Best regards.
Materials.7z
Options_Flux_materials.doc
EmSt likes this
