Sign in to follow this
stefano1
Differencies between markers
I have a question. I want to know how to set properly the markers on a body. I've seen that I can activate three kind of markers on a body: CM coordinates; Inertia Coordsys; Body Coordsys. What are the differencies? I have the model of a car that is moving thanks to a constant rotational speed applied on the wheels. If I want to steer my vehicle, which kind of marker allows me to define the correct rotational speed vector? In other words, I want to know how can I define a coordinate system that moves with my body/graphic.
Thanks
Stefano
To attach a marker on a body, a location and orientation need to be specified.
Create a marker and attach the same to the body.
Hi, I want to know if the marker will follow a certain direction in its movement, i.e. I want to know which kind of marker of the bodies tab I have to use
