Hi all,
Is there any command available to find surfaces which are very close to each other. I have 2 components and there are some locations where the surfaces are really close(like contacts), need to find these surface ids without any manual selection.
Hi Vipin,
try using hm_collisioncheck (refer to hm help)
set output for mark_id_pene_surfs
you may need to set an appropriate thickness for surface component
Hi tinh
*createmark surfs 1 "displayed"
hm_collisioninit
hm_collisionentitycreate surfs 1 0 1 0 0 0 0 0 0
hm_collisioncheck 0 0 0 1 0 0
hm_collisionend
hm_highlightmark surfs 1 "low"
right now my code looks like this. I cant find any option to assign surface thickness! how to do that?
Hi Vipin,
maybe the example given in hm help is wrong!
Below code is working in my hm2017, please try it (T1 is thickness of surfs in comp1, T2... comp2):
proc p_GetContactSurfs {CompId1 T1 CompId2 T2} {
   hm_collisioninit
   *createmark surfs 1 "by comp id" $CompId1
   hm_collisionentitycreate surfs 1 0 10 $T1 0 0 0 0 1
   *createmark surfs 1 "by comp id" $CompId2
   hm_collisionentitycreate surfs 1 0 10 $T2 0 0 0 0 1
   hm_collisioncheck 0 0 0 1 0 0 0
   hm_collisionend
   hm_highlightmark surfs 1 low
   hm_getmark surfs 1
Pandurang likes this
Really?
T1 and T2 are thickness values to apply to surfs
in my test:
comp1 (ID 1001) has surfs 1 2 3 4 5 6 7 8 9 10
comp2 (ID 1002) has surfs 11 12 13 14 15 16 17 18 19 20
I invoked:
p_GetContactSurfs 1001 1.0 1002 1.0
it worked!
This command will assign thickness to the surfs
in hm help, it says add 10 will add thickness to outside of surfs
maybe your surface normal is inward
could you try with number "30" - will add thickness to both inside and outside of surfs
   hm_collisioninit
   hm_collisionentitycreate surfs 1 0 30 $T1 0 0 0 0 1
   hm_collisionentitycreate surfs 1 0 30 $T2 0 0 0 0 1
   hm_collisionend
   hm_getmark surfs 1
p_GetContactSurfs 1 1.0 2 1.0
Can you please try on this model, I dont know what is going wrong.     find_nearby_surface.hm
   hm_collisioninit
   hm_collisionend
   hm_getmark surfs 1
No no Vipin, a critical bug at the second "hm_collisionentitycreate", the last argument must be "2" instead of "1"
it is group id of surfs that will be pushed into hm_collisioncheck
I test your model, it return surfs 4 9 3 2,  (thickness option 10 or 30 are all OK)
please try again and announce me
Pandurang and vipin like this
