Sign in to follow this
suryanshu walvekar
Error 1109 (No TH variable defined)
Please check the TH field.
If we create a data file using TH/NODE and we did not define the title by mistake ...then the job errors out.
Please share the complete .out file to understand better.
Hi there,
The simulation ran successfully, but there is no . h3d file generated. Where to get it from.
Also is there other way by which we can access results, there are following files which were generated.
crash ag_0000.out
crash_ag_0000.rad
crash_ag_0000_0001.rst
crash ag_0001.ctl
crash ag_0001.out
crash ag_0001.rad
crash_ag_0001_0001.rst
crash agT01
From the out file I see that the frquency of animation file is zero.
Please use ANIM/DT in Engine and provide a frequency to write out animation file(s).
Hello Prakash,
I ran the analysis in hyperview, but the car(component - part 1) seems to go through the guardrail (component - rail). It seems there is nothing happening between the contacts.
What have I done wrong please guide me.
Thanx
Surya
Also Prakash one more thing,
I have students version of Hyperworks which doesnt allow separate Radioss application I guess.
Is there a way to assign more threads to simulation.
I used to do it in the radioss application window earlier when I had the full version.
Surya
No, this is one of the limitations with SE.
Regarding the simulation, there is no contact between the barrier and the car.
Please create contact between the car and the barrier and try again.
