Mrt
edge_to_surface contact
Hello all!
who have had problem like me and have solved it?
i'm trying to do edge_to_surface contact in optistruct.
i can't add model.
if i have large model with ribs panel will impact to them.
could you give me any tricks to win it?
thanks a lot.
17 hours ago, Mrt said:
i can't add model.
Hi @Mrt
Can you explain what you mean by "can't add model", please?
There is no separate edge to surface contact in OptiStruct as in RADIOSS, but N2S will help.
Unfortunately, auto-contact may not help to model.
@jiaru72300
@Prakash Pagadala
thanks, but i've yet tryed n2s, it's didn't help.
i tryed to create pairs ribs tube; and tube to ribs S-M and M-S, but it hasn't worked. i have been solving it issue for 3 weeks!
it issue have yet solved in NONLINEAR geometry implicit solver in optistruct (it uses radioss ), but i have got a task to convert it in quasi-static nonlinear static.
small ribs have distorted while plate has deformed.
have you got any idea, guys?
Can you try with Large displacement analysis?
Here I am attaching a small model file with LGDISP activated and has an edge to Surface contact,
Edge.fem
hello @Prakash Pagadala!
of course, i have used large displacement analysis. it's my first goal to use nlstat large displacement analysis instead implicite nonlin-geom analysis.
thanks a lot, i'm going to see your file!
could your give me any advice how to solve large strain in my issue?
i think the problem is large distortion of elements.
you can see, i tryed to use finner mesh, but it didn,t help.
i'm just newbie in altair solvers, i have been using abqs for a long time.
I can see that you are using PCONT with FREEZE on it. Is there a reason for that?
Can you change the stiffness on PCONT to AUTO instead of soft and check if that helps?
Also, please add CNTSTB card.
No. i have written about it in privious message. i've done finner mesh, i thought it will has helped. but i was wrong. there mesh has been connected grid to grid. i had released it and did finner mesh. and after it i've done TIE (for altair it's freeze). do you understand my explanation?
thanks, i will try to use your advice and after it i will write about the results.
