Sign in to follow this
Teja
how to get torque as an output as result
hello,
I am working on model of pressure plate which have axis offset. A shaft passes through it. when pressure applied (in x-y) on the pressure plate due to the offset one side of pressure plate will have more pressure. Which causes rotation on around z axis. As the shaft passes through z-axis. Shaft and pressure plate are in contact.. As pressure plate will rotate it will tend to rotate the shaft. I want to find out for particular pressure how munch is torque is generated.
i want to get torque as output when pressure is applied. how to get torque as direct output
Hi Teja,
We have forwarded your query to the Commercial technical support team. They will get in touch with you soon.
