Sign in to follow this
Hyperman
tension only 1D element
how to set up tension only (no compression, bending and torsion) 1D element in Radioss?
I have tried with truss and spring elements. However, truss elements have axial compression stiffness and there is discrepancy in the plots, possibly because of geometric non-linearity.
compression (truss in blue, spring in red color)
tension
spring_truss.hm
hello!
i haven't opened your model.
at first, i don't now about altair, but it doesn't recomend to use no tension/no compression to beam/truss elements in abaqus.
i'm looking for your model and will give some advice, but i'm just newbie in altair solvers.
it's interesting, becouse i thought if i splite truss to 2 element i will have no compression force. i'm confuse, but it doesn't work in radioss...
Hi Mrt,
thanks for your input.
My observation is if the force or displacement is applied coaxial to the truss/beam elements they will not buckle in compression, since FEA does not model material or geometry imperfections that would buckle the structure in reality.
