Ankitmehta11
Disc brake analysis
Have you take a look at these tutorials from OS documentation?
First you impose a clamping force, then apply a small rotation and then run complex modal analysis.
If that's what you mean by roatation, it is all there in this tutorial.
OS-T_ 1370 Complex Eigenvalue Analysis of a Reduced Brake System.pdf OS-T_ 1371 Brake Squeal Analysis of Brake Assembly.pdf
Nagaraj likes this
1 hour ago, Nagaraj said:
Thanks @Adriano A. Koga I referred OS-T_1371 and with the help of Altair support I successfully run the model.
Apply the angular displacement carefully ! The results in optistruct depend on the angular displacement (in the second step) which is not the case in the CEA formulation ...
