chirag bangera
Unable to assign Material to part for a step file
I imported a part from UGNX as  a step file. This model was assigned with some material to it in UGNX. But in Inspire when I tried assigning material to it, its mass is still showing zero kg. How can I overcome this problem?
Can you check if your part only contains surfaces but no solid volume?
You could open Property Editor in View menu, and check the thickness or volume of your part their. Does your part have non-zero volume?
A zero mass part indicates a part that is not solid. Please use the Patch tool to check if there is an opening in your solid that makes our geometry being a shell only. You can use this same tool to close that gap and convert your geometry to a solid.
Matthieu
